Mercedes Benz Forums
Mercedes Benz Forums - Photo Galleries - Create an Account - Mercedes Benz cars
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Diesel Discussions
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Mercedes Forum today!
Thread Tools Search this Thread
Old 10-31-2009, 01:44 PM
Dex40 Dex40 is offline
Default Windows don't work on an 82 300sd
I'm looking at a 1982 300SD for purchase, but the windows do not operate. Also the mirror adjuster switch that sits between the windows switches does not move the mirror. The fuses all look good. Does anyone have any ideas what possible things might be wrong. Just looking for an idea of what I might be getting into?
Thanks.
Register today for free or log in if already registered to remove this ad!
__________________
Just another rookie mechanic.
Old 10-31-2009, 03:06 PM
ForcedInduction's Avatar
ForcedInduction ForcedInduction is offline
Super Moderator
Send a message via MSN to ForcedInduction
Replace the fuses anyways. The tips often corrode off the fuses and break connection.
__________________
www.youtube.com/Turbo617
Old 11-01-2009, 01:17 AM
Diesel9112 Diesel9112 is offline
Quote:
Thanks.
Below is a pic of one of my Window Fuses. As Forcedinduction said it looked good a first. But, when I pulled it out I got a surprise.
One Fuse connects to 2 windows 1 front and 1 rear; however they are acrossed from each other.
Anoter common problem area can be the Switches. They get full of crud and the Contacts inside the switch get burned up a little.
In the last pic below you can see the the red arrow pointing to one of the burned contacts, but, they are all burned to some degree. I scraped them carevully off with a knive and the Window worked again.
__________________
84 300D, Volvo 244GL Diesel
Old 11-01-2009, 01:29 AM
I forgot to add there is also a Power Window Relay behind the Instrument Cluster. However, I have not read of anyone having to replace one yet. But, I also have not read of a case where none of the Windows function at all.
Normally some will work or at least partly work.
If both Rear Windows will not work there is a Child Safety Switch that can go bad and it will cut off the power to the rear windows.
__________________
Old 11-03-2009, 11:43 AM
TargaNF TargaNF is offline
You can test the window motor with a 9V battery. Behind the door skin is two wires that come from the motor.
They screwed to two other wires going to the relay.
Unsrew the wires and put the 9V on the window motor wires only. Should do something. + on + and - on - is " up " and + on - and - on + is " down "
If you want a little more power you can use a set of jumper cables off you battery. But a regular 9Volt battery is a little easyer.
Also its a good idea to clean out the gunk from inside the window switches like the above post said to do. I have had a switch stick down and blow my window motor.
Hope it helps.
Jay
Tags
1982, 300sd, benz, benze, features, fuses, mercdes, mercedes, mercedez, rear, switch, switches, window, windows, work
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
