87 300 Diesel - Pre-glow light not working...does not start when cold? PLEASE HELP
Hi All,
I have a 87 Diesel (SDL). Its Pre-glow indicator lamp on the dash stopped glowing after the key is turned on, hence it does not start when the engine is cold. What could the issue be and how can I fix this problem? Please help.
Thanks for pointing me to the GP relay box with a photo. The relay strip fuse (silver bridge) appears new and intact (not broken). Also, there appear to be no burn marks inside the box or any corrosion on connectors and pins. Anything else I can check?
Also, another issue I discovered is that the fan in front of the radiator remains on the whole time while the engine is running. I believe it is only suppose to turn on when the engine is hot.
patricknif
03-04-2012 06:38 AM
lovedabch
07-12-2007 10:29 PM
Xacting
10-18-2006 12:42 PM
