PAS pump triggers off alarm!?! SLK 320
Old 07-25-2008, 02:56 PM
rooobpl's Avatar
Default PAS pump triggers off alarm!?! SLK 320
Hello,
Doors lock and unlock automatically when pushed from inside or on a speed trap orwhen turning fast. Alarms goes off sometimes (a couple of times a week) with no reason. Merceds says it has to change PAS pum control unit as this init apparently isresposnible for alarm, doors and PAS. Anyone has been there?
SLK 320 2000
Robert
Old 07-25-2008, 02:57 PM
rooobpl's Avatar
Default RE: PAS pum triggers of alarm!?! SLK 320
Hello,
SLK 320 2000
Robert
Old 07-25-2008, 05:46 PM
052453a's Avatar
Default RE: PAS pump triggers off alarm!?! SLK 320
Take it out and clean it. There's hope there just may be some moisture, not flooded with water. If successful, make sure you find the leak, and modify the placement of the unit.
Old 07-28-2008, 10:51 AM
Mine went last month, could only open the doors with a key and roof would not go up and down, changed the PAS pump and been great since
e320cdi786
01-30-2010 06:37 AM
rooobpl
07-28-2008 01:41 AM
tawfiq
11-01-2006 12:56 PM
tawfiq
10-28-2006 08:52 AM
mercstyled
01-11-2006 11:09 PM
Quick Reply: PAS pump triggers off alarm!?! SLK 320
