SLK230 Kompressor out run by Geo Metro. Help!
Old 06-15-2010, 02:55 PM
CobraV8's Avatar
Default SLK230 Kompressor out run by Geo Metro. Help!
I just posted this in the General tech area and then saw this SLK forum which is probably more suited (new guy here). Here's a link
https://mercedesforum.com/forum/general-tech-5/slk230-kompressor-out-run-geo-metro-help-43105/
Malcolm
Old 07-06-2010, 09:42 PM
neilevan's Avatar
To start with, my 1998 goes 0 to 60 mph in under 6 seconds, and has blown away Corvettes from a dead stop, so you must certainly be in "limp home mode."
As far as the sticking top, it's a common problem. But reach into the hood hinge track on the left you'll find a wire and a loop with rubber padding. Pull it out between the bristles and leave it out. Give a tug before parking the car every time and your top will always drop. If this doesn't do it, try the pull wire under the plastic panel on the right side of the trunk. Same story.
Old 07-07-2010, 09:46 AM
CobraV8's Avatar
Blown away corvettes? sorry but I find that one extremely hard to even remotely believe. Are you sure the Vette was racing?
Anyhow thanks for the tip on the roof but we just sold the car. It was such a pile and had so many problems it was just not worth messing with anymore.
obrienre
08-01-2015 08:48 AM
CobraV8
06-15-2010 02:50 PM
Scotlass
08-14-2008 07:46 PM
MASTERBENZ
06-28-2008 07:15 AM
redrockmountain1000
03-07-2008 07:42 AM
Quick Reply: SLK230 Kompressor out run by Geo Metro. Help!
