plz Help Radio dont work signal weak
Hi recently I had my factory SLK2301998 Casettle player replaced with aftermakret Pioneer.
Before the Install only one of the popular radio stations worked rest signal was weak
The Installer tried to use an Antenna Adapted but signal was weak but when he squeezed the top part of the antenna the singal would get strong. Now I have no Radio Working. Each time he sqeezed the Mercedes Antenna front silver part which went into the Anteena adapater which then went into the stereo.
Plz Help as I listen to the Radio alot
RE: plz Help Radio dont work signal weak
if i were you, i will squeeze his nose for doing a bad job.
obviously, the problem is the antenna.
there are reasonable electronic shops where you can get internal antenna which you can easily install yourself.
go get one.
go get one.
Yamaha91
12-19-2010 12:04 PM
bright rider
09-12-2008 02:03 PM
