SLK 320 air filter removal? - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
Old 02-18-2007, 10:35 PM
Default SLK 320 air filter removal?
What is the easy way to remove the housing ***.to remove air filter.Is there a special tool.I would like to replace it with a K&N.Thanks
Old 02-19-2007, 03:53 AM
Default RE: SLK 320 air filter removal?
You just pull the whole black cover thing (which includes the filters) sharply upwards.
I don't recommend changing the entire assembly for some after market fit assembly.
Why do you want to change the air filter type or are you just referring to the paper elements?
What will you achieve if you get rid of the whole assembly?
You may end up with MAF problems.
Stuart
Old 02-19-2007, 05:13 AM
I just wanted to replace the element only not the housing.By pulling it upward is it fastened by studs?Will anything break?So you are saying the whole unit comes upward in one piece.
Old 02-19-2007, 10:21 AM
Yes
I also dont understand why people think other filters are better then the MB one?
Bazzle
Old 02-19-2007, 10:47 PM
Hey bazzle thanks for your time.I had no intent on ever changing out the assembly just the filter.
Old 02-20-2007, 05:04 AM
Yes. Just jerk the whole cover upwards and it will come away. Its held by 4? rubber bobbins. Best to grip it half way down each side and spread the loading as much as possible.
Don't be timid....on the other hand don't be too forcefull. No screw type fixings are used.
Stuart
Old 02-20-2007, 11:30 AM
Quote:
ORIGINAL: bazzle
Yes
Bazzle
At the bottom of the page is an ad for K&N filters. Guarantees more power, sunny days, etc. If you guys weren't here I'd probably believe it too! Darn banner ads!
Avery
Thread Thread Starter Forum Replies Last Post
*Brand New* BMC Air Filter Mercedes *All Class with Dual Air Filter* FB262/01 (Pair) StickyBenz For Sale / Trade Classifieds 0 02-01-2012 07:24 PM
Auxiliary Battery: Air filter cover removal Sparky33 Mercedes E Class 1 02-15-2010 04:53 PM
How to change Cabin Air Filter and Air Filter parasuco Mercedes C Class 2 03-13-2009 03:21 PM
SLK 320 air filter removal 1ragtop General Tech 1 02-19-2007 09:55 AM
How to change the air filter for the air conditioner in 2002 ML320 BlueML320 Mercedes M Class 1 10-22-2006 05:02 AM
Tags
2005, 2007, 320, air, change, class, filter, installation, location, mercedes, remove, replace, replacement, slk, slk320
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
