SLK 230 Kompressor stalls when stopped, won't crank
1999 SLK 230. Recently began having a problem where the car just wouldn't crank. All lights, radio, access. work, fan will engage and you can hear the turbo click, but the engine will not turn over. After 5-15 min, car cranks and runs fine. Mech checks and finds no error codes. Now, car stalls when stopped at red light, then will not crank for 5-15/30 min. When it finally cranks, runs fine. Again, Mech check and no error codes. All the research I've done points to the CPS being faulty, but the Mech says he's not able to test when the car is not acting up.. and it will not act up while he's tinkering with it. Any suggestions???
Hope this helps...
Thanks for the response. I ended up biting the bullet and replacing... just hated throwing the money at a fix that we're not sure IS the fix. Happy to say,, at least after 3 days, everything seems to be working ok. No stalls or crank failures. Tomorrow, the mrs's will be driving it,, if it makes it through her test run with no issues, I'll feel confident.
Thanks again for the response.
jspskompressor
11-25-2010 10:49 AM
lockster
10-25-2010 05:25 PM
