Maintenance schedule
Anyone have a link to a online maintenance schedule for a 2000 slk 230, have 70,000 miles on mine and haven't done anything except strictly oil changes and topping off fluids every 10,000 miles, did the air filter at 35,000 miles and replacing my MAFS today, I was told by several mechanics that cleaning the MAFS is just a temporary fix and that the check engine light will come right back on in a few months. What cause the MAFS to go bad so soon?...I was told if I changed my air filter every 20,000 miles that the MAFS will probably last forever.
RE: Maintenance schedule
Why did you change the MAF? 35k is an unusually low mileage for failure.
The MAF "fails" (at least when signalled by fault Code P0170/3) as a consequence of "deposits" adversely effecting the temp/resistance curce of the hot film sensor. The "base" setting of this resistance is checked as part of startup checks and if outside limits sets the CEL. Prior to setting the CEL the vehicle begins to increasingly run lean causing intermittent misfire possibly on just one or two cylinders.
A burn off cycle used to be used on the old hot wire sensors but I think that the technology change precludes this. Either way deposits build up..
Cleaning can permanently remove these deposits (very sensitive to cleaner used) but sometimes cleaning does not work.
Not sure if town running is any different to the open country from a deposit point of view.
The proposition re filter changing is interesting and may have some validity but I suspect it is caused by particles smaller than the filter is design/capable of removing.
ORIGINAL: Slkboi2000
