Transmission Fluid Type for 560SL - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
Old 04-09-2006, 09:27 PM
Default Transmission Fluid Type for 560SL
I have a 560SL (1987) and I need to know what is the recommended automatic transmission fluid to use. Please be specific. Thank you
Old 04-30-2006, 06:44 AM
Default RE: Transmission Fluid Type for 560SL
I have found Red Line to be one of the best.
I have seen this oil fix a car that was having problems shifting into gears. Once it was in the car I never had a problem again with the gears.
If anyone knows other wise please let me know. I have yet to find better oil for my cars.
www.redlineoil.com
Old 12-05-2006, 05:59 PM
I have a 87 560 SL too! What kind of motor oil do you use? They said I need to keep the oil plentiful to protect the chain.
Old 12-05-2006, 10:12 PM
French7,
The motor oil you use will be somewhat dependent on external temperature. For example, in sunny, warm FL, where I am, I use Castrol or Kendall 20W50. If I still lived in NYC in the winter I changed grades to 10W40. Whatever you choose, in my opinion, never use any synthetic oil in your engine. The synthetics high detergent content will act almost like a flush in your engine and get it too clean and your seals will almost assuredly begin leaking. MB recommends synthetics for it's newer engines as they were designed for it. The 117 engine we have was not.
Bob
Old 12-13-2006, 01:54 AM
You can use Dextron III or if you want to spend some serious money you can use Amsoil syn., ATF which is what I use in everything. Had really good luck with it. Just remember when U change the fluid you need to drain the Torque Converter too; i let mine drain overnite.
As far as Oil is concerned you can use synthetic and it won't hurt anything. I use Mobil 1 in both my 107 and my wife's Lexus. Had really good results. Occasionally you might run into a situation where the engine leaks a little cause synthetic doesn't have seal swellers in it like conventional oil. but your engine will last a lot longer and the timing chain will benefit too.
Thread Thread Starter Forum Replies Last Post
type of trans fluid? carnut General Tech 4 06-25-2012 12:22 PM
Benz CLK 320 1999 Transmission Fluid Type? Reinaldo-Ray Mercedes CLK Class 0 02-26-2011 12:19 PM
14"x6.5" and 14"x7" Wheels / Rims 1982-1985 Type (123 & 126 Type) raltherr For Sale / Trade Classifieds 0 11-21-2010 11:23 AM
14" x 6.5 Wheels 1982-1985 Type (123 & 126 Type) raltherr For Sale / Trade Classifieds 0 09-03-2010 05:19 PM
Hydraulic fluid type ramminjammin Mercedes S Class 2 06-27-2005 08:49 PM
Tags
107, 1987, 560, 560sl, 7224, benz, dextron, fluid, iii, kind, mercedes, oil, recommended, requirement, sl, transmission
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
