SL320 1995 – digital temp gauge
Old 08-31-2012, 06:48 AM
thisislou's Avatar
Default SL320 1995 – digital temp gauge
The reading of the outside temperature starts off let it is correct – then runs up like 20 - 30 degrees F higher than it really is. I’m guessing the sensor needs to be replaced?
Lou
Old 09-05-2012, 01:24 AM
brookings's Avatar
the part is cheap enough for a try. You can check the values of the sensors by turning the ingnition to position 2. press REST and within a second press the 4 button for your fan speed control. use the F and C buttons to go back and forth checking readings. 02 Is the inside car temperature sensor, 04 outside sensor, 06 evaporator sensor, 08 heater core, etc. you're more interested in 04. that's is the temperature being fed to the climate control module.
Old 09-06-2012, 12:37 AM
brookings's Avatar
might as well give them all. 12 is engine coolant temp, 14 is temperature selector wheel setting, 18 is the vehicle speed signal, 20 is soft top open (u) or closed (o), 22 is the power supply voltage and 84 is the voltage to the blower motor. 83 is not used
Old 09-12-2012, 09:45 AM
thisislou's Avatar
Grest information - I'll give it a try
thanks
Lou
ddtbreakfast
04-21-2008 11:34 PM
awais_s
07-20-2006 05:25 PM
black_pearl
05-01-2006 09:49 PM
micko30
10-11-2005 02:32 AM
bishos1e420
08-25-2005 04:13 AM
Quick Reply: SL320 1995 – digital temp gauge
