Hydraulic fluid leak--SL500 1997
#21
RE: Hydraulic fluid leak--SL500 1997
If any of you are having problems with hydraulic cylinders leaking, I can rebuild any of the 12 hydraulic cylinders for an R129 SL for $30 each + $10 total shipping. I highly recommend that you have the cylinders repaired in pairs. I will warranty the seal I replace for 3 years. In most cases I will have your cylinders back in the mail the following business day after I receive them. You can find discussions about my work on benzworld.org and mercedesshop.com in the SL forums. I also repair the cylinders for the W124 convertible for the same charges.
Dennis Ficken
16285 S. Chester
Olathe, Ks 66062
(913) 390-0506
mercedescylinders@sbcglobal.net
mainshipmed@sbcglobal.net
Dennis Ficken
16285 S. Chester
Olathe, Ks 66062
(913) 390-0506
#23
You could probably use any high quality hydraulic fluid, but I recommend that you only use MB hydraulic fluid. You wouldn't want to risk damage to either the pump or the solenoid valves just to save a few bucks on the fluid.
Dennis
Dennis
#24
Dennis,
Several have written that the 'alternate' hydraulic fluid is Febi/Bilstein P/N 02615. Since this stuff is around $10.00/ltr, it makes an interesting financial alternative, but until proven that this is the identical 'stuff', your advice is well founded on sticking with the MB branded...as much as that pains my wallet!
Bob
Bob
#26
M-B Hydraulic Fluid P/N 000 989 91 03 10
@$20-$30/liter froma Stealer.
Interesting...searching onthat part # in a few of my favorite parts places on the net, brings up the Febi/Bilstien #02615 Hydraulic Fluid. At pricies ranging from $9-$10/ltr. Works for me-
Bob
Bob
#27
ORIGINAL: SunGuy62
Bob
Bob
Iseem to remember some other strings that you and I have been on that mentioned staying with M-B hydraulic fluids so as not to have any additional problems.
Do you know if they willsend fluids? I can't remember where I read that some Internet parts guys will not sendproducts like fluids due to safety guidelines.
#28
ORIGINAL: lynns
Bob,
ORIGINAL: SunGuy62
Bob
Bob
The bottom line for me, is that I'll use the Febi alternative; but that hardly means I endorse its use, or encourage anyone more risk averse to use it; simply a possible cost effective alternative to the high priced spread.
On shipping, sincethe MBparts suppliers on the net are listing this material on their sites, along with antifreeze, power steering fluid, etc. that they ship already, I'm surethis hydraulic fluid isavailable for shipping as well.
#29
ORIGINAL: SunGuy62
Lynn, yes, a few posts back on this forum I said I would stick with the MB branded fluid.Subsequently doing a little research at the Febi-Bilstien site along withsearching on the MB part# convinced me that Febi is the OEM for this material, puts it in the same blue bottle, only difference seemsto be that pesky and expensive 3-pointed star.
000989910310
Mercedes (OE) Hydraulic/Suspension Fluid; 1 Liter , $20.00
0009899103
Febi-Bilstein Hydraulic/SuspensionFluid; 1 Liter, $10.00
I woulddefer to Febi at http://www.importeccatalog.com .Actually the Febi p/n is whatthe STAR Classic Service Manual calls out for. The only problem I have is the additional shipping cost of $8.38.
