do I have to replace all Hydraulic cylinders??
Old 06-05-2007, 04:53 PM
maserati's Avatar
Default do I have to replace all Hydraulic cylinders??
Hi Members,1993 500SL,hd cylinder on the right side below the hatch is leaking (spray's a small amout of oil on the 1/4 panel)stopped using the top right away.Everybody is telling me,I have to replace all cylinders $ $$$$ ,is that true or just a money maker story,never a problem before with the Top.any help???thanks Thomas
Old 06-05-2007, 05:15 PM
SunGuy62's Avatar
Default RE: do I have to replace all Hydraulic cylinders??
maserati,
Your question is a good one and since we have found a quality re-builder for the cylinders, you probably can do them all without breaking the bank, but most of us just have the leakers rebuilt as they fail. The only caveat on that last statement is where the cylinders are in pairs, like the front latches, even if only one side is leaking, do them both. If the one you describe in your car is the one I'm thinking of, it's got a twin on the other side. If true, recommend doing both.
These things fail due to age and heat drying out the cylinder seals. The rebuilder everybody uses can give you the best advice on what to do with the remaining cylinders. Suggest you contact....
Mercedes Hydraulic Cylinder Rebuilder
Dennis Ficken
16285 S. Chester
Olathe, Ks 66062
(913) 390-0506
mercedescylinders@sbcglobal.net
Dennis charges around $35-40/per cylinder + shipping, warranties for 3 years, and turns them around usually in one day after receipt. He's done a couple for me and hundreds of them for others. He can also help explain how to get them out of your car.
Good Luck
Bob
esc1999
06-10-2015 12:48 PM
bwrumfel
01-27-2011 08:14 PM
MrMBenz47
12-31-2004 12:47 AM
beater 57
07-21-2004 03:14 AM
Bobin
11-12-2003 09:47 AM
Quick Reply: do I have to replace all Hydraulic cylinders??
