brake booster problem on 99 SL 500 ??
99 SL500, when I press the brake pedal I hear air hiss. It is not a constant hiss,only when I press the pedal when the pedal stops the hiss stops.
What do I need to replace ? Also,can not get shifter out of park unless push brake pedal very hard.
Thank you.
Thank you.
try having someone apply brakes while listening to brake vacuum booster under the hood behind the master cylinder. a stethoscope might help, a paper cup is better than nothin'. unusual for the diaphram to go bad. I've never had to deal with one.
joe4324
11-09-2007 07:55 AM
