1997 ABS/ASR Failure
Old 01-20-2005, 10:50 PM
parrotheadfl's Avatar
Default 1997 ABS/ASR Failure
I have a 1997 SL320. Occasionally, while braking, the ABS and ASR failure indicator lights come one. They remain on until the car is restarted. While they are on, the ABS, ASR and cruise control do not work. The manual says when the ABS stops working, the ASR automatically fails as well so I think the problem it with an ABS sensor. It sounds like an easy fix that I would like to do myself and any helpful information would be greatly appreciated.
Thank you,
Hank
________
IOLITE I-INHALE
Old 02-07-2005, 11:54 PM
Default RE: 1997 ABS/ASR Failure
Still haven't been able to figure this one out. I figured I would mention that the problem typically only happens when I brake in reverse and when braking lightly.
________
Hot penny stocks
Old 02-10-2005, 03:29 PM
bobterry99's Avatar
If you take the car to a dealer, they ought to be able to very quickly diagnose the problem through diagnostics. That said, you might simply try replacing the brake lamp switch. It is a common cause of the problem you describe, is inexpensive, and is easy to replace yourself.
Old 07-27-2005, 03:24 PM
ORIGINAL: parrotheadfl
Thank you,
Hank
Additionally, the problem only happened when braking lightly, heavy braking did not set off the sensor.
The problem was fixed by removing the two front vehicle speed sensors and cleaning the metal shaving debris that was stuck to the magnet on the sensor. The task is easy. See the picture.
[IMG]local://upfiles/4497/BD16E6027C9643EEAB25527B15EFFF26.jpg[/IMG]
________
Ipad guides
Old 02-14-2006, 06:27 PM
i had a very similar problem- it turned out to be my stop light switch..$23 from the dealer, 15 minute install and took care of all the problems you describe...the bad switch was sticking intermittantly ...i have a 99 sl500...hope this helps, george
punk760
12-15-2008 12:53 PM
97clk200
12-10-2008 01:37 AM
goldwingmike
12-03-2008 01:05 PM
lxshk
08-07-2008 08:28 PM
E300TD
01-26-2005 07:00 AM
Quick Reply: 1997 ABS/ASR Failure
