1992 sl500 locking system problem
Old 04-28-2015, 05:50 PM
springglen6's Avatar
Question 1992 sl500 locking system problem
Has anyone suggestions for drivers door not locking or unlocking door from outside with key. Using passenger door or trunk the system works fine and unlocks and locks all including drivers door, but no result from drivers door.
Is it a difficult job to access the door system? I have had the panel off other times for other issues but have not accessed the lock part of the system.
Old 05-10-2015, 12:29 PM
96SL500's Avatar
Location: Manatee County, Florida- Sarasota mailing address
The pump is in the right hand side of the trunk. I believe that even when you use the key the compressor moves air. You might look for a leak. You might even hear it when you use the remote and the trunk is open and pump uncovered. I have to be truthful though, I haven't used a key since I purchased my 96 in 2007.
Minsring
11-02-2011 09:36 AM
manirm
08-02-2009 12:45 AM
delboy277
05-12-2009 05:19 AM
c2201995
12-30-2008 04:35 AM
fwillie
10-08-2004 01:24 PM
Quick Reply: 1992 sl500 locking system problem
