Window on WDB 220 Strange Power Window
Old 04-13-2008, 07:49 PM
Rockerfella174's Avatar
Default Window on WDB 220 Strange Power Window
My Window Rear Left Just went down while driving without touching any buttons on it..
and sometimes the central locking system does not function at all
the stranges part is the rear trunk just automatically opens it self ..
any advice?
rockerfella174
Old 04-20-2008, 09:52 PM
Default RE: Window on WDB 220 Strange Power Window
Sounds like a problem with the master window control switch in the driver's door. It also contains the trunk release switch. The control assembly could be dirty or corroded due to water dripping on it. Another thing is that when the door is open and shut numerous times the wires in the loom at the hinge can break especially in cold climates. This will lead to problems with wires broken and grounding against metal. Maybe you could try removing the master window control assembly and cleaning it with an electronic type cleaner spray.
js234
04-03-2011 04:10 AM
rsxvscell
09-19-2009 04:59 PM
commando9000
08-10-2007 11:08 AM
BigFP
12-17-2004 09:47 PM
honeybee
10-29-2004 02:24 PM
Quick Reply: Window on WDB 220 Strange Power Window
