Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Mercedes S Class
Sign in using an external account
Register Forgot Password?
Search
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Mercedes Forum today!
LinkBack Thread Tools Search this Thread
Old 10-09-2006, 06:07 AM
Default S500 Airmatic Problem
I have a Mercedes S500 AMG equipped with Airmatic system which is not working at all. The multipurpose display says, 'Airmatic, STOP, CAR TOO LOW!'. i think it is an electronic fault. Can anyone tell me which module controls the airmatic system?
Register today for free or log in if already registered to remove this ad!
__________________
Tawfiq
Old 10-09-2006, 06:23 PM
Default RE: S500 Airmatic Problem
is the ride height the same, or is the car sitting a lot lower??
__________________
~2004 Mercedes-Benz S430~13K Miles~White~Black Interior~Active Ventilated Front Seats~Chrome Headlight Surrounds~Chrome Mirror Covers~Chrome Handles~
Old 10-10-2006, 07:47 AM
sleepwalker's Avatar
Send a message via ICQ to sleepwalker Send a message via Yahoo to sleepwalker
vovpar, you speak the language of true experienced W220 guy now. i think you really did learn a lot.
once the red airmatic warning appears on the multifunction display, the airmatic system is dis-abled. actuating the switch might activate it, but if not... there's a problem.
if there's ride height problem, then a leak could be present.
if the pump is faulty or the valve is leaking (run time exceeded)... then it will shut off.
it is wise if he can tell us more about the symptoms.
__________________
support - Solar Energy
Old 10-10-2006, 06:47 PM
thanks sleepwalker,
i have same problem with mine, but i mine is sitting all the way down and i need to do the coding.
cant wait to get the car done!!!
__________________
Old 10-11-2006, 02:28 AM
so it must be coding on the SAM, EIS, ESP to indicate if you got airmatic or ABC (active body control).
__________________
Old 10-11-2006, 09:54 PM
probably, i'm taking it for service tommorow, finnaly put everything back together and going to programm it tommorow.
Wish me Luck
__________________
Old 10-11-2006, 09:55 PM
Quote:
ORIGINAL: tawfiq
i'm going to let you know what dealer says about this issue....
__________________
Old 10-12-2006, 05:01 AM
Dear Sleepwalker
Thanks for your reply, now;
First of all, the car is sitting too low. front tyres went inside the fender.
You said actuating the switch might activate it, how do I do that? where is the actuating switch?
How can i check if the pump is working or now?
What is the coding thing? how it works? I'm actually new with Mercedes but I am a techi, you can try me. Please help me with this.
__________________
Tawfiq
  #9
Old 10-12-2006, 05:46 AM
then you got a leak. if both front are down with the same level (+/- 2cm), then the valve/pump must be leaking.
if the other side is a bit higher, then it's a shock absorber air leak.
the raise and lower switch is located in the upper control panel. it's together with rear blinds, anti-towing, etc.
the pump is located on the fron right bumper (concealed). you can listen to it or any hissing sound.
coding is what takes vovpar to dig deeper into his pocket now. it is programming the computer/control unit to recognize installed equipments in the car.
__________________
  #10
Old 10-13-2006, 02:11 AM
coding i not that expensive, but it adds up if you tow the car to the dealer couple times[:@]
__________________
Tags
2001, 2004, air, airmatic, cls, control, leak, mercedes, module, problem, problems, s430, s500, shock, ventilation
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
