S320 Right front door - No power
All the controls on the right front door of my S320 have stopped working (electric seat regulation, window power, mirror,..) The problem seems to be a fuse but I am not able to locate any fuse related to that symptom (just fuse f39 right window power) it in the fuse diagram. Any help will be very much appreciated.
RE: S320 Right front door - No power
Thanks very much for your response Sleepwalker. I think it will be more difficult to fix it by myself than I thought. However do you know were the right door control module is located and if it easy to replace?.
98 = w220? Really. I thought w220 was intro 1999.
Sleepwalker is (as always) spot on.
Likely water ingress (valeting etc). Sometimes just disconnecting and reconnecting can clear the problem which MAY BE corrosion on the multiconnector pins.
MB bits are expensive.
Not sure I agree with the ease of removing the door trim local to the switch unless you are use to so doing. Several hidden screws etc.
Needs CAREFUL removal of the "wood" (painted aluminium!!) strip (prises out) to gain access to the various screws etc.
Stuart
Stuart
arnottdoug
03-04-2015 12:33 PM
arnottdoug
03-04-2015 12:30 PM
PWeber
06-19-2007 03:13 PM
