rear end noise
rear end noise
300 te wagon 1989 when I bought this wagon as I drove it there was a constant hum
as if you were flying a sortee heading to a bombing mission in a B 52.
The guy I bought it from said it needed rear tires well I know I am a fool that was not the case. Next got my trusty mechanic who knows nothing about Mercedes or as I now
know rear ends he went to junk yard a picked up another differential I guess put it in and total cost 1200 now it still sounds like pearl harbor.
I have been driving it now for a couple of months i just don't know how to proecd
any idea of problem and soultion and estimate? thanks Milage 172229
hi,
Sounds like a worn off bearing hub/Wheel bearings do try and check you waterpump ive experience that on my MB 1990 500SEL. These are wear and tear parts that u need to look upon.
if during idling still making the same noises well go and check on the fan clutch/Belt fan tensioner bearing/belt drives/alternator bearings/ these noises are related on parts moving.
btw do have a look on the long shaft mountings if they are harding / cracks/ damage. do replace them it will makew noise/ chassics shake in small vibrations at certain speed.
lets us know on the outcome ok
good luck
rockerfella174
good luck
rockerfella174
axle, benz, class, cost, differental, differential, e320, end, mercedes, noise, rear, s430, s55, suspension, wagon
