Antenna mast question??
Old 11-03-2006, 10:00 PM
apollo_10's Avatar
Default Antenna mast question??
Hi everyone,
Can anyone help with this...
On my 96 s320, the antenna only goes 3/4 down (it's angles back 30degrees) when the radio is off.
As a newer owner...I noticed the the S500 (it's angled perp. to the ground) antenna goes all the way down is there something wrong with my car?
Old 11-04-2006, 10:23 AM
Peter Guenther's Avatar
Default RE: Antenna mast question??
The fender mounted antenna is on a angle with the fender, perhaps it is bent and therefore can not retract thru the chrome nut. The suggested replacement is to remove the nut turn on the radio and it will eject the shaft and the toothed winder. The replacement is in reverse, turn off the radio insert the winder untill it is captured and let it wind in. I have found that the easiest way is to have someone turn off the ignition which stops it, feed in the shaft and start the nut and then let it go all the way.
or see if you can find the kink in the shaft
Old 11-04-2006, 03:23 PM
apollo_10's Avatar
Thank you Peter,
I will try that with a new mast.
Seems pretty basic DIY.
techteam
08-11-2010 03:14 PM
lsworonoff
08-24-2008 02:10 AM
Chadted
08-23-2008 06:34 PM
81 300 CD
08-20-2006 12:39 AM
benzowner
05-11-2005 11:50 PM
Quick Reply: Antenna mast question??
