100.000 km service
Old 01-01-2007, 04:04 PM
pinky1970's Avatar
Default 100.000 km service
hello im new to the forum, i own a ml320 and it has done 100,100 km and is due a service soon , can anyone tell me what the garage should be checking, is there some things they should check like cam chain, auto box, axel oil , it is still under warranty at the moment and i want to know what they should be checking. also there seems to be some noise coming from the engine and it sounds abit like a disel, like noisy valves and the exhaust is abit noisy under the hood any ideas to this.
Old 01-03-2007, 10:49 PM
jjk6tar's Avatar
Default RE: 100.000 km service
if the noise sounds like its coming from in front of your window meaning by the mirror then the converter could be leaking. I have 110,000 on my but at 107,000 I had to replace the converter for it was split at the weld. In an earlier forum, a writer stated that due to an early recall the dealer replaced his for free and that was with 1250,000 miles. I bought my used my a dealer and didn't know about the recall.
I had the dealer due my 100K which is the usual service but I had them change the trans fluid and the gas filter. ( cost mea little over $1300)If the wires and plugs haven't been changed they would be due.(I did them myself) But you can figure another $600. If the converter needs replacement I'm told you can figure about $1500 for one side(thats if they don't cover it under warranty) I replace my own.Good luck
Old 02-07-2007, 11:43 AM
Hey...I have a 2000 ML 320. You can have your local MB authorized repairman do all that you stated EXCEPT for the Cat Converters. Mercedes Benz still has a recall on all converters. I had 2 replaced in August 2006 and I had 114K + on the clock so right there you can save yourself a lot of cash.
v12powers
09-01-2010 01:18 PM
frankie21
05-21-2009 12:42 PM
djweiser
10-18-2007 02:56 AM
theleadingagent
06-26-2007 08:44 PM
jimmyhml320
01-22-2005 12:15 AM
Quick Reply: 100.000 km service
