srs light on - how to reset????
While replacing the blend air motor I neglected to disconnect ml320 battery. This required removing passenger air bag. Now srs light is on. Folks have mentioned that this requires trip to dealer to reset. Does any know if they use obd2 scanner to reset or some other tool?
Hello Scott
I replaced the lock actuator and with the airbag disconnected I turn on the key to check the glass window was ok and I now i got the SRS light ON.
I'm wondering if you found a way to reset the SRS light?
Thanks in adavance.
Thanks in adavance.
dlite922
12-26-2009 02:45 AM
95ee320
11-27-2006 05:14 AM
