Question on my 98 ML320
Old Dec 16, 2007 | 09:59 AM
blp320's Avatar
Default Question on my 98 ML320
I get some chattering on turns when i accelerate. Being a Ford Tech. I se this once and a while on the Fords. The ML has 25k miles on it and so i replaced the front and rear siff fluid with the reccomended fluid from MB and I added friction modifier to both front and rear. It has to work itself in for a couple of days in order to fix it but is this a common problem??? Also I feel as if my cooling fan clutch is always engaged. I hear the fan LOUD when i accelerate. Has anyone ever had these problems???
PS I'm new.
Old Dec 16, 2007 | 11:56 AM
chassis221's Avatar
Default RE: Question on my 98 ML320
that is considered normal for the 98 ML. it is more prone to the 98's rather than the other years as per mercedes benz tech bulletins.
Old Dec 16, 2007 | 01:34 PM
blp320's Avatar
In the TSB's what do they say the fix should be. Is it what i did? or is ther some special MB friction modifier out there i have to use?Also, is there a TSB on the faan clutch?
PS
Thanks for the responce.
BoostingTurboNut
Feb 28, 2009 11:34 PM
kastan97
Dec 23, 2008 01:36 PM
lentomies
Nov 19, 2008 02:02 PM
8092400e
Oct 22, 2006 12:19 PM
donandmm
Nov 23, 2005 01:51 AM
