320 idler pully replacement
Old 07-27-2010, 07:29 AM
Charlie of Alabama's Avatar
Default 320 idler pully replacement
I have a 1999 ML230. I idler pully split and shereaded the belt. How do you pull off idler pully to replace it? 17 mm socket slipping off tensioner. Any suggestions there? Thanks
Old 07-27-2010, 09:49 AM
Should be 320 ML not 230 ML
Old 07-27-2010, 04:27 PM
chassis221's Avatar
should be a 17mm under the pulley or you have a T8 torx bit on the center of the pulley itself there is a holding hole to hold the tensioner while replacing it. 2 screws to take out the pulley easy fix.
bballfreak
03-13-2015 08:04 AM
craig w
12-14-2014 12:29 PM
2002c230benz
02-10-2006 02:45 PM
piperca
01-22-2006 01:47 PM
MLCLUELESS
12-28-2005 10:13 PM
Quick Reply: 320 idler pully replacement
