ML500 2002 brake problem !
Old 02-06-2007, 12:05 AM
maurim3's Avatar
Default ML500 2002 brake problem !
Hi i have 2002 ML500 im having braking problems... and i would like to know if anybody has the same problem as me... this is the problem... when you press the brake its like it goes deep and doesnt brake good it doesnt make that back preassure... so you have to press it real hard to make the truck stop. .the car has been taken to the dealer and they just changed the fluid and said nothing happens... it doesnt leak anywhere.. does anyone has some idea of what this could be? thanks
Old 02-06-2007, 03:26 PM
Default RE: ML500 2002 brake problem !
Dealer is not very good if they cannotfind the problem, choose a brake specialist. Sounds like calipers may be frozen or pads too thin? I have mine done at a brake shop that does all vehicles not just Mercedes. He has been very good so far. Also have the Master Cylinder checked, it provides the pressure from the pedal and should have a vacuum assist as well that5 may be suspect.
Old 02-06-2007, 08:31 PM
maurim3's Avatar
Ok. thanks a lot.. ill try to take it to a brake specialist tomorrow!
Old 02-08-2007, 09:51 PM
This happens a lot on ML's....usually happens after someone replaces brake pads....Dive fast and step on the brake really hard...try to get the ABS pump to turn on and build pressure.....You usually have to repeat this many times to get the pump to build up pressure again....Also keep an eye on your brake fluid level...The fluid might be leaking from your master cylinder into your brake booster...
Old 03-05-2007, 03:01 PM
MBZTech,
I recently bought a used 2002 ML320 Sport. The vehicle has had a soft brake petal since Ipicked it up.
I followed your instructions above as far as finding some empty highway, getting up to speed (around 60 Mph) and braking very hard. Amazingly, it worked perfectly! The petal is firm and the brakes seem to work much better than before. I was ready to do a front brake job to get a better petal feel, but now will wait for the pads to wear down. Thanks again!
JP
sales406
08-02-2012 08:10 PM
Abe Simpson
10-10-2011 10:45 AM
HDYLUN
11-30-2009 10:29 PM
antares1944
09-11-2009 09:46 PM
shannoninocala
03-05-2008 05:54 PM
Quick Reply: ML500 2002 brake problem !
