ML350 HK Subwoofer Location
Greetings,
My ML350 has the standard sound system to which I want to add a subwoofer. Plans are to install the OEM subwoofer with an aftermarket amp. My question is, Where was the HK Subwoofer installed?
Thanks,
David
Thanks,
David
I have a 2009 ML350 with the HK system, I'm going to unload some parts and clean it, I'll snap you pics if you'd like. I'm actually about to look into that a little bit, as I'd like to separate off the HK SW as a mid-bass and use my 12W7-3 as the sub.
