ml320 v6 petrol missfire
Old 07-03-2015, 11:41 PM
corb1's Avatar
Cool ml320 v6 petrol missfire
my ml320 misfires when I touch the brake pedal at idle when stationary,I don't know which cyl it is but the engine hunts really bad until the pedal is released.....the diaphragm in the brake booster appears to be ok.There are two sensors at the front of the booster when I disconnect the plug on the small one it does not misfire but I don't know what the sensor is for...
Old 07-04-2015, 03:14 AM
dreamer no2's Avatar
So when you put you foot on the brake it will slow the engine a little .And in doing so will show up your misfire even more . I dont know what the part is your talking about can you put a picture of it please.
Old 07-04-2015, 06:02 AM
corb1's Avatar
Default ml320 misfire
The engine runs fine at idle.....it only drops cylinders when I touch the brake pedal....I am thinking the sensor I described maybe possibly something to do with the cruise control function that is venting vacuum to atmosphere due to a fault or break in the vacuum hoses that disappear under the manifold.... but I am not sure...I will try and put up a picture if I can...
lentomies
11-11-2010 05:36 AM
666baddy
01-03-2008 09:38 AM
Malcolmho
08-20-2007 10:45 AM
BoostedAudi
03-05-2007 07:13 PM
cl55
02-25-2007 04:29 AM
Quick Reply: ml320 v6 petrol missfire
