ML320 - turn the key and the engine won't turn
Old 08-19-2006, 03:24 AM
jazharp's Avatar
Default ML320 - turn the key and the engine won't turn
Thanks to all you folks that help out on this forum. You guys are all great - sorry for the many posts, but wanted to keep suggestions separate.
My '98 ML320 does this weird thing sometimes. I turn the key in the ignition and the engine "blips" for a tenth of a second and then won't start. Sounds like it wants to, but no. I end up locking the doors electronically (with the key), then unlocking them, reinserting the key and try again - usually works 2nd time sometimes 3rd time. Any thoughts on this? I replaced my batteries in the keys and it still does it.
Thanks in advance for taking the time to read this.
Bart
Old 09-14-2006, 06:10 PM
AMGMercedes's Avatar
Default RE: ML320 - turn the key and the engine won't turn
So you think your key is preventing you from starting your car? Maybe because since your key uses an anti-theft system that may be the issue. The vehicle has to recognize the key using infra red, electronically...something like that and maybe it's not the key, but the reciever. ?
Old 05-25-2016, 09:30 AM
keepnsimple's Avatar
Having the same problem. My engine blips a couple times but won't start. Did you ever solve the problem?
Goldengirl1
11-08-2012 07:28 PM
s_gilbride
07-04-2008 09:33 PM
LegalNeeds
06-24-2007 12:14 PM
gerryp300dtd
04-17-2007 09:13 PM
Quick Reply: ML320 - turn the key and the engine won't turn
