ML320 temperature gauge at 3/4 level
Old 07-27-2006, 02:30 PM
ml320_driver's Avatar
Default ML320 temperature gauge at 3/4 level
I have noticed in the past few days that the temperature gauge in my car is at 3/4 level instead of in the middle as it had been.
I checked the coolant level in the expansion tank and it is ok. I did not see the 2 fans in the front of the radiator run even at this temperature, wouldn't they ? I pull out the big fuse for the fan for AC and wasnt able to tell if it is blown. Any thing I can do further ? any advice ?
I was about to take the car to have the coolant system flushed and refilled, is this the right thing to do ?
Regards, KB.
Old 08-01-2006, 12:51 AM
Default RE: ML320 temperature gauge at 3/4 level
should go up and then back down , check the aux fan fuse . does the a/c coool at idle? if it does ur problrm is normal operatiion
Old 08-30-2006, 03:26 PM
I have the same problem, and never go back down. The water and fans are OK[:@]
Old 07-08-2007, 06:54 AM
when you say 3/4, about what temp is that. My truck is a little of 80. and I keep getting the coolant lamp warning while driving and later goes off. what should be my concearns?
Old 07-10-2007, 08:35 AM
We were having that same problem (engine temp. 3/4 of the way up) and took it to the dealer. They couldnt find anything because it "checked out ok". Also, the A/C was blowing warm during this time. Took them to another dealer and found that the 30amp fuse was blown and the wire harness that runs the aux. fans was shorting out. Apparently Mercedes had a retrofit kit for this wire harness that was never installed.
John
PelicanParts.com
06-11-2013 05:30 PM
builderdude
09-16-2010 11:17 AM
ddtbreakfast
04-21-2008 11:34 PM
NMB
06-18-2007 11:26 AM
zeaq
01-05-2004 09:49 AM
Quick Reply: ML320 temperature gauge at 3/4 level
