ML320 heater unit not working - Mercedes Forum - Mercedes Benz Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 01-30-2008, 07:28 PM
Default ML320 heater unit not working
Hi Guy's - I have a 00' ML320 - and I cannot get the heater to work. The fuses are fine, the relay is working ( already had replaced with new one by dealer ), the water is hot, the blower motor operates. When I select the heater via the temp **** and set the vents to foot and windshield, and turn on the blower, it blows ambient temp air. When the temp **** is changed to cool and vents set for dash it blows super cold air. Problem is the mornings have the windshield iced and the interior cold, and I cannot get the heater/windshield defroster to operate - Blow hot air. Anyone with help it's appreciated. It's my only vehicle and I can't afford to have it spend a day or two at the dealer awaiting inspection. Thanks
Old 02-08-2008, 10:45 PM
Default RE: ML320 heater unit not working
THERE IS A AUX. WATER PUMP THAT SUPPLIES WATER TO THE HEATER CORE. IT IS RIGHT NEXT TO THE BATTERY. THIS FEEDS A GOOD SUPPLY OF WATER TO THE HEATER CORE TO HELP HEAT UP CAR FASTER ON COLD MOURNINGS. YOU SHOULD BEABLE FEEL THE PUMP WORKING WHEN THE CAR IS STARTED FIRST THING IN THE MOURNING, WITH THE HEATER ON.BEST OF LUCK.
Thread Thread Starter Forum Replies Last Post
s320 will not start, heating stopped working lights on dash not working help patricknif Mercedes S Class 0 03-04-2012 07:38 AM
Keyless not working not key not fuse Paul Dalton General Tech 0 02-07-2012 03:37 PM
1985 300D California EGR Control Unit / Tach and AC not working killo1 Diesel Discussions 1 06-14-2009 07:21 PM
Heater not working correctly. Madlions Mercedes C Class 0 10-10-2006 06:14 PM
AC Heater FAN Not Working S600 mikem9 Mercedes S Class 1 06-10-2005 11:56 AM
Tags
320, blower, blows, control, controls, heat, heater, heating, mercedes, ml, ml320, motor, problem, work, working
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
