ML320 Hard to sometimes hard to start
Old 05-31-2008, 09:26 AM
tarrantb's Avatar
Default ML320 Hard to sometimes hard to start
I have a 1999 ML320 that is hard start from time to time. We can drive it than Park than come back and it spins like its not getting fuel or firing. If you let it sit for a while it starts with no problem.
Old 06-15-2008, 01:40 AM
tongster's Avatar
Default RE: ML320 Hard to sometimes hard to start
I have a 99 ML320 and that exact thing just happened to me today.
Can anyone help with what the problem could be?
Old 06-16-2008, 12:41 AM
It was happened with my car, and i just changed the part name oxygen sensor then it start well
Old 06-16-2008, 01:42 PM
I had the same problem with my 2002 Ml320, in my case I changed the fuel filter and problem went a way.
Old 06-20-2008, 12:14 PM
HAS IT EVER STALLED? IF IT HAS STALLED THEN I SAY CRANK SENSOR.
Old 06-29-2008, 02:25 AM
tongster's Avatar
going to change the crank position sensor next week and will let you know what happens.
Old 11-28-2010, 06:48 PM
areyestwo's Avatar
Default hard to start
did you fix the problem? what was it? thanks.
Old 12-01-2010, 08:08 AM
mbenz80's Avatar
In 99% of these cases the crank position sensor is the problem. In oldere model with two locking tabs one on each side of the sensor for electric plug, Mercedes part number
A0031539628 Bosch 0261210141. I believe '98-mid '01.
Newer 01 on sensor with one connector locking tab is A0031532728 Bosch 0261210171. Just make sure you use OEM Bosch otherwise you will have to do it over soon.
you should be able to find them on internet for around $50 or at dealer for about $150.
These are heat sensitive when they get older and that is why when you let the engine cool off for like half hour you are able to start it again with no problem.
Good luck,
Bernard
  #9
Old 12-01-2010, 08:41 AM
i617gem's Avatar
I would like to change the CPS, Does any one have a diagram of the crank position sensor for a ML320
  #10
Old 12-03-2010, 01:25 PM
areyestwo's Avatar
mbenz80. thank you. i'll try the cps.
walpoleauto
01-21-2011 08:17 PM
widmer
10-19-2007 03:14 PM
col190
10-03-2007 09:10 AM
bookerzisme
01-12-2006 08:43 PM
aharley1
03-27-2005 03:01 AM
Quick Reply: ML320 Hard to sometimes hard to start
