ML320 Front Brake Replacement
Old 01-16-2004, 09:41 PM
Raechella's Avatar
Default ML320 Front Brake Replacement
I have a ML320 and trying to replace the front pads. How do you get the rotor loose, and/or off for replacement?
Old 06-12-2004, 08:38 PM
Default RE: ML320 Front Brake Replacement
Once you get the wheel and caliper off, there is a simple looking screw in the rotor that you need to remove. After that, the rotor should come off with a little muscle. The lug nuts keep the rotor on the hub, along with that single screw.
Old 06-12-2004, 10:42 PM
sleepwalker's Avatar
i wonder why you want to remove the rotor by just replacing the front pads?
Old 06-13-2004, 01:07 AM
Maybe his rotors are worn. When I changed mine, I "miked" it to see.
gyoshioka
11-19-2011 06:37 PM
btorsiello
10-26-2004 07:09 PM
nuwave2000
04-14-2004 01:47 PM
dimple212
02-28-2004 12:11 PM
erictfree
02-13-2004 09:00 PM
Quick Reply: ML320 Front Brake Replacement
