ML 320 fuel trim problem
Old 04-21-2017, 11:15 PM
V0nd00123's Avatar
Default ML 320 fuel trim problem
Hello all,
I bought Ml 320 W163 4 Months the ago, engine performance is very low so I have done
- injector cleaning
-MAF cleaning
-air flow cleaning
-plug changing
-fuel pump change
-plug change (using Bosch platinum plus)
Following is the current OBD2 code, mechanic are saying all sorts of thing, Pls advice which area I should troubleshoot
Old 04-27-2017, 01:38 PM
I would address the cylinder misfire first as that could be the most serious of the issues. I've also attached a DIY on the O2 sensor replacement.
Mercedes-Benz W203 Oxygen Sensor Replacement - (2003-2005) C320 | Pelican Parts DIY Maintenance Article
harryco
01-10-2008 12:34 AM
webberkyle
10-16-2007 09:53 PM
webberkyle
10-15-2007 11:58 AM
benzowner
06-05-2007 11:52 AM
benzowner
08-10-2005 01:32 PM
Quick Reply: ML 320 fuel trim problem
