ML 270CDI Transmission problem
Hi Guys,
Can anyone help!
I have a 2000 mdl ML 270 turbo diesel and the Auto transmission is free reving when changing between gears 3 and 4 and occasonaly goes into limp mode (stays in 2nd gear) when it does this if i turn off the engine and select park and start car again it comes out of limp home mode.
I have had it at the dealers and they have hooked it up to the dianostic machine but cant find a fault. They dont know where to start and sugest tranny will have to be pulled apart to find out whatys going on (sounds expensive).
Has anyone else experianced this problem in there ML and what was or could be the cause.
Hoping someone knows something about this, regards,
Scott
RE: ML 270CDI Transmission problem
ORIGINAL: fromcoyle
Hi Guys,
Can anyone help!
Scott
Hi Guys,
Can anyone help!
Scott
Regards,'Jerry
#9
On older transmissions, I have heard that tranmission fluid can migrate up the control cable wiring harness and begin fouling up the tranmission computer. I am cosidering changing this cable asembly when i do my next trans fluid change as my Ml is 10 years old and has 161000 miles on it
I believe there is a TSB on this.
Jim in Phoenix
Jim in Phoenix
#10
I have 99 ML320 and I've replaced my tranny by myself (it took 12 hrs. streight-whole Labor Day under the car) last year at 132k miles. The electric connectorfrom transmission to module was full of transmission fluid and dirt. I used electric contact cleaner to wash the plug and compressed air to dry it a couple of times before it was nice and clean. The fluid is not a lifetime fill, as MB engineers planed. Need replacement as any other car so first, I would clean the electric connector and replace fluid/filter. Plus tranny has fault codes readout too to find out possible cause of failure.
I hadthe same problem, limp mode symptoms with 93 Dodge Intrepid transmission (copy of BMW tranny) it was speed sensor! There is two of them, one for input and one for output speed. At 60k miles we paid $700 to dealer to fix it but the second time at 120k miles, I've replacedthem myself and cost $50 but they are external part of the tranny.
On ML all sensors are mounted inside of the transmission. Good luck with your MLs.
