Ignition and Key - car thiks key still in ignition when withdrawn
I have a problem that I am sure others must have had with my 1998 ML320 - when the key is withdrawn from the ignition it used to make a little "click" and this would mean the car knows the key has been withdrawn - but recently the "click" only happens intermittenly (less and less) and when the key is withdrawn the car "beeps" and the doors will not lock with the fob. Is there an easy fix? It seems like the plunger that senses the key is not working or is sticky.
RE: Ignition and Key - car thiks key still in ignition when withdrawn
OK - extensive research has now cmade me think that the ignition switch is faulty. Apparently it has a sensor which feels when the key is in the ignition, and it is worn out/getting stuck - so the car thinks the key is still in the ignition in position "0". Hence the beeping when the door opens, and the non-functioning of the remote locking mechanism. Anyone know if the replacement of the ignition switch is easy? I suspect that it is attached to the back of the ignition cylinder and that sounds like a mess to play with - but if anyone knows of an easy way to replace would be helpful.
Ignition won’t reconize key!!
