How to turn low range off stuck in the on postion
Old 11-17-2007, 11:45 PM
xxdanielxx's Avatar
Default How to turn low range off stuck in the on postion
hey i am new here and i have a 98 ml 320 that has the low range lite on i dont know how to turn it off can any one help thanks
Old 11-18-2007, 10:25 AM
chassis221's Avatar
Default RE: How to turn low range off stuck in the on postion
car running, put in neutral, then push low range button, should go back to normal range.
Old 11-18-2007, 11:19 AM
xxdanielxx's Avatar
tried that all it dose is blink 3 times then it stays on is there another way to do this thanks
Old 11-18-2007, 11:27 AM
chassis221's Avatar
TRY TO ENGAGE DRIVE WHEN IN LOW RANGEAND DRIVE IN LOW RANGE, THEN GO TO NUETRAL AND SWITCH TO REGULAR RANGE AND TRY DRIVEING IT. DOES THE CAR ACTUALLY GO IN TO LOW RANGE ( REVS MUCH QUICKER BETWEEN GEARS) OR DOES THE LIGHT JUST STAY ON? YOU COULD NEED A TRANSFER CASE MOTOR IF THE LIGHT DOESNT GO OUT. i WOULD KEEP TRYING TO SWITCH BETWEEN LOW AND HIGH RANGE A FEW TIMES. LIGHT IS SUPPOSED TO STAY OFF.
Old 11-18-2007, 11:32 AM
xxdanielxx's Avatar
i think it is on low range when i drive it it feels like a bus slow cannot go fast will try what you said i know last time i took it to the shop and the guy did something here turned the wheels and push some buttons and boom it went away not sure what he did.
Joefillipino
12-09-2011 12:20 PM
redtees1
06-20-2011 03:13 AM
tim66
08-05-2010 08:48 AM
fastmike99
10-28-2006 04:21 PM
Quick Reply: How to turn low range off stuck in the on postion
