how to improve gas mileage ML350
Old 03-25-2011, 03:26 PM
hlsess's Avatar
Default how to improve gas mileage ML350
I live in a city /suburb with hills and lots of stop signs.
My city mileage is terrible- around 15 mpg
On the highway I get 22 MPg
any tips? I use the middle grade gasoline
Old 03-25-2011, 05:17 PM
trigger's Avatar
Hi, My ML350 does alot of coasting down hills and I try to keep the speed to 45MPH on the country roads. Not saying the mileage is that much better than you get, but, my hubby put clean air filter on , hope it improves..... In Ohio the weather is on a warm up soon.... No air on this summer...
Old 03-27-2011, 08:02 AM
hlsess's Avatar
My car salesman said it was OK to use the middle grade- I'll use premium and see if it helps
Old 04-07-2011, 09:39 AM
mbenz80's Avatar
I'm not sure about 350 engine but since January, I have switched back and fort between the premium 91 and lowest 87 grade that Costco (Amoco) offers.
My car is idling much smoother on 87 octane and I'm getting exact same mileage out of both grades, around 260 miles per 16 gallons of fuel.
Maybe same "engineer" was writing the manual to use the premium only, who also suggested not to change the transmission fluid because it is a lifetime fill !
In my old 280, I could see and feel the gas difference in gasoline grade and in 10 years, I used premium Shell only.
Bernard
Old 04-07-2011, 08:42 PM
617OHMS's Avatar
Default M-p-g e-t-c
Has anyone used 4x4 adapter to put a stick in a 300SD?
Way back they used to have free-wheeling in some cars.
I drove a 54 ford with free wheeling. I got great MPG.
Anyway back to the stick. In other car, a beetle 1.9 diesel stick, I roll in neutral great distances when traffic is slow. Basically, I idle a lot. It significantly improves MPG. Going 2nd to 5th helps too.
Seems like a 300SD stick could benefit. Plus be a ton of fun.
I'm new to this forum. Used to just drive my MBs, and played with the others.
Now interested a little tweaking in the MB world.
Old 04-08-2011, 02:23 PM
mbenz80's Avatar
Originally Posted by ForcedInduction
Ah so you, a typical owner, knows better than a multi-million dollar company's engineers. Sure.
Yes, a typical Mercedes owner could be also an engineer with higher education and more experienced then any of them working for Mercedes. Why not?
Old 04-08-2011, 02:42 PM
Migael's Avatar
Why not send it for dynatuning, you will have better performance and fuel consumption?
regional23
07-04-2008 06:21 PM
bb1080
05-23-2008 01:41 AM
tygman
06-15-2007 03:08 AM
RockSolid
11-14-2005 08:55 PM
cam69ss
10-25-2004 02:45 PM
Quick Reply: how to improve gas mileage ML350
