full set of brakes still screeching
Old 12-10-2008, 02:29 PM
mosesmcneil's Avatar
Default full set of brakes still screeching
Hi everyone looking for a bit of help/info i have a 02 ml270 and my local mechanic (mercedes approved) replaced my brake discs callipers and pads (pads now changed twice and got the expensive ones) but there is still a very loud screeching when i brake but only at low speeds. What can be the problem is it the type of discs?? I got the brakes fitted about 5 months ago
Old 12-13-2008, 01:53 AM
Default RE: full set of brakes still screeching
Is your problem only when pads are cold?
Old 01-05-2009, 03:39 PM
Your problem is that your mechanic didnt use lube on your sliders. Gonna have to take them off and regrease them to prevent chatter.
Old 01-05-2009, 05:15 PM
Les4Parts's Avatar
Back in the 80's Mercedes decided to do something about the squeal problem they were having so they started experimenting with brake pad composition and rotor hardness.
Eventually they came up with a pretty good formula for both resulting in almost no squeal but increased brake dust.
Now their pads and rotors are well matched with only an occasional complaint of squeal.
They do have a paste that comes in a little foil pack that is used on the back side of the pad to help prevent squeal. P/n A 001 989 94 51 10 if I remember right.
We also used a fluid made by MOC Products to saturate the pad lining to help. Although this is not factory recommended and I'm not sure of the availability.
Here's the thing though. If your repair shop CAN'T diagnose and fix the problem you need to change repair shops.
If they are using non OEM parts then the pad and rotor compositions are mismatched and this will cause a squeal. My recomendation: Take it to the Factory Authorized, Trained and Equiped Dealer when your independant fails you.
Marcus 600
03-07-2012 12:45 PM
Laura75
12-01-2010 10:32 PM
ebart5
06-06-2009 05:24 PM
mosesmcneil
12-12-2008 02:16 AM
bemmerguy714
12-01-2005 11:04 PM
Quick Reply: full set of brakes still screeching
