Electrical Problem Cropped Up
Old 06-30-2015, 04:13 PM
phjohnso's Avatar
Default Electrical Problem Cropped Up
I had several things stop working last week on my 2007 ML350 - I looked around and eventually tested all fuses with a circuit tester - the following fuses have no power to them at all
100 - front wipers
46 - cigar lighter
50 - rear wiper
59 - head restraints
60 - front wipers and glove box light
61 - airbag
THESE ARE ALL THE ITEMS THAT ARE NOT WORKING ON THE ML350
What am I looking at - Relays? I don't feel anything click when i turn on the wipers.
I need a clue - can anyone advise me?
thanks in advance.
Old 07-03-2015, 04:51 AM
dreamer no2's Avatar
H can you see any bus bars in the location .They look like flat alloy thin plate with two bolts to hold them in .These are a fuse also. They do blow just like a fuse .
Old 07-03-2015, 05:01 AM
phjohnso's Avatar
I will deffinately look around and see if I can find any - thank you for the tip
Old 07-05-2015, 06:17 AM
phjohnso's Avatar
I didn't see any bus bars - would anyone happen to know if I should find them and where they would be on a 2007 ml350?
thanks in advance
Old 07-05-2015, 08:16 AM
PH dont bother with the bus bar . I see you have 4 fuse boxes, and i really think you must find them all and do a thorough check on them all first for blown fueses . And i think you will find some fuse boxes in the trunk area..
Old 07-06-2015, 04:41 AM
This is a good site ,check it out google again - Repair.Pal dont forget the dot.
Old 07-06-2015, 04:50 AM
Go to google search again in the box put - Repair.Pal.com 2007 Mercedes ML350 .Lots of info on here for you.
kurnia.2
02-11-2015 03:43 AM
4XXXX
09-01-2008 01:52 AM
and42is
08-16-2005 10:33 PM
rifle
12-05-2004 07:03 AM
Quick Reply: Electrical Problem Cropped Up
