Dash Board lights are out OBD not connecting at the Inspection station
Old 10-16-2008, 03:03 PM
jmramesh's Avatar
Default Dash Board lights are out OBD not connecting at the Inspection station
I need help for a 2000 ML320 that I own I am not sure both theseproblemsare related
Problem : 1 ) When I turn my headlights on the dash goes black (meaning the lights on the dash goes out) I switchheadlights off the dashboard lightscomes back on. I checked all fuses and none of them seem to be out
Problem : 2 ) The Inspection stations (I went to 2 places)are not able to connect to OBD the display says something like "Error unable to establish connection" however when I took it to a mechanic he was able to connect to it and actually showed me an error code which is causing the check engine light to come on need to change the Air mass flow sensor.
Iwill greatly appreciate your kind help
Thank you
Old 11-27-2008, 10:04 AM
Default RE: Dash Board lights are out OBD not connecting at the Inspection station
On problem 1, turn on lights then turn the multifunction switch on the instrument panel. This switch has a dimming function when the light switch ison.
jose paulo
09-13-2010 10:29 PM
mlhoust
12-22-2009 12:37 AM
ELockhart
01-28-2009 11:28 AM
mab
11-06-2008 01:01 PM
lilrob_84
12-26-2007 09:40 AM
Quick Reply: Dash Board lights are out OBD not connecting at the Inspection station
