cruise control
Old 08-19-2008, 09:50 PM
ispt17's Avatar
Default cruise control
I have this car from 1 month, (2002 Mercedes ML320 ) and I have a problem, pls help me. The cruise control doesn't work anymore...is worked ...if somebody can tell my ...thx
Old 08-19-2008, 09:54 PM
chassis221's Avatar
Default RE: cruise control
wrong tire sizes from the left side to the right side? did you get new tires? traction control issues? faulty brake switch? check to see if the brake lights are on all the time, that will cause no cruise control. also check fuses.
Old 08-19-2008, 10:10 PM
ispt17's Avatar
Thx for answer, will check
Old 08-20-2008, 10:36 PM
ispt17's Avatar
Yes, I check and the problem is the stop light they stay on all the time ...know is a big problem ....probable I have to go to a garage...I hope is not big deal
Old 08-21-2008, 12:42 PM
chassis221's Avatar
easy fix you can do it yourself if your somewhat mechanical it just twists to come out and a new one goes in the same way. just push the little tab in then twist.. when you install the new one pull the button out on the switch( the new stop lamp switch then install). obviously remove under dash panel first ...2 or 3 phillips screws
budsl600
02-09-2005 12:29 PM
goodluck
12-03-2004 03:39 AM
Randy
12-01-2004 11:48 PM
madrat
08-12-2004 10:31 AM
06-08-2004 10:02 PM
Quick Reply: cruise control
