Mercedes Benz Forums
Go Back   Mercedes Forum - Mercedes Benz Enthusiast Forums > Mercedes Benz Models > Mercedes M Class
Sign in using an external account
Register Forgot Password?
Search
Welcome to Mercedes Forum!
Welcome to Mercedes Forum.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Mercedes Forum today!
LinkBack Thread Tools Search this Thread
Old 06-28-2009, 12:51 PM
Default Check Engine light w/ error codes: P0170 & P0173
My check engine light is on (2001 ML320) and the error codes P0170 & P0173 come up when I had them check it at Autozone. They couldn't cross reference them to the mercedes. Does anyone know what the problem could be? It seems to be running fine...
Thanks!
Register today for free or log in if already registered to remove this ad!
Old 06-28-2009, 01:38 PM
mbenz80's Avatar
Your self adaptation reached limits.
P0170 - Self adaptation of the partial load or idle mixture formation for right cylinder bank to limit value of ME-SFI control module (N3/10)
P0173 - Same thing just for Left cylinder bank
Could be air leak, fuel injectors of diaphragm-type pressure regulating valve, wear to engine
I would suggest to check all four CO2 (oxygen) sensors or your air supply tube to throttle valve body came loose.
__________________
1999 ML320 203K miles
2003 Lexus GX470 268K miles
1980 280SE EURO W126 156K miles 142mph SOLD
1984 300D TURBO DIESEL W123 SOLD
Old 06-28-2009, 03:15 PM
The same error code showed up on my 1998 C230 too. Rather than trying to figure out the problem(s) as suggested in the other posts on this forum (which I did and ended up wasting a lot of time) my advice is to bring it to a mechanic with the Mercedes Benz STAR diagnostic scanner (basically a laptop) and it will tell you exactly what the problem is.
In my case, it was the MAF. So I bought one from autohauz (https://www.autohausaz.com/search/pr...ber=0280217114) and was able to replace it myself.
Tags
2001, 320, benz, check, clk, code, codes, determining, engine, error, light, mbz, mercedes, messages, ml320, p0170, p0173
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
GetCoolParts.com
Monroe, WA 98272
360.863.0557
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
