Brakes & Rotors
Old 03-04-2009, 09:22 AM
BIG AL's Avatar
Default Brakes & Rotors
Does anybody know where to purchse the brakes and rotors from besides the dealer cause these guys are killas
Old 03-05-2009, 11:36 PM
mbenz80's Avatar
Hi Al, did you ever buy anything of e-bay. Just mae sure they are OEM. What truck do you have? I have set of front OEM Textar Brembo pads for ML430 and ML500. My ML is 320 and my pads are different, so I will not be able to use them. Check for The Brinson Company, they are distributor and receiving shipments from Germany for MB and BMW.
Old 03-17-2009, 07:21 AM
m1943's Avatar
Has anyone thought of using ML500 breaks in an ML350? Back when I had an ML430, the breaks were different from the ones on ML320. I presume that the same goes for 350/500. I'd like to have better breaks, once my OEM set begins to need replacement. Probably would change just the front calipers and rotors, if such a swap is at all feasable.
Old 03-18-2009, 10:50 PM
mbenz80's Avatar
I have 99 ML320 and I was checking out for brake upgrade like you. It will cost around $1000 for complete Brembo set same as used in ML55, ML500 and some ML430.
Old 03-19-2009, 02:10 AM
m1943's Avatar
Is that just swaping out calipers, rotors/pads, or is there more to it?
Old 03-19-2009, 03:34 PM
mbenz80's Avatar
That should be it.
carid
01-02-2023 09:02 PM
PelicanParts.com
07-08-2013 11:08 AM
justaride
03-25-2010 06:44 PM
mercedes1990560sel
01-18-2010 07:42 AM
benzthere
07-15-2009 06:29 PM
Quick Reply: Brakes & Rotors
