BAS, ETS,ABS,Brake lights flashing
I have a 2004 ML350 and the BAS, ETS, ABS yellow and red brake lights flash and beep as soon as you turn the car on. I have the following codes: p0720, c1020, c1046, c1045, c1026, c1022.
I checked the fuses and swapped the k12 relay - no help. I pulled the connector from the ESP module and it was clean with no corrosion. The car is in limp mode. Pushing the ESP button has no effect.
I have alldatadiy but can't find any troubleshooting for chassis codes. Any help would be appreciated.
Will Batista
04-25-2012 10:29 PM
igorml
11
09-13-2011 09:46 AM
mbell321
02-22-2006 06:40 PM
