99 ml 350 low range when start car - Mercedes Forum - Mercedes Benz Enthusiast Forums
Thread Tools Search this Thread
Old 06-22-2007, 10:23 AM
Default 99 ml 350 low range when start car
ML 350 139,000 miles, when I start vehicle the low range light flashes, I'm not sure if it is going into low or not, runs fine, at cruising speed tach is about 25, anybody have any thoughts or suggestions. Does anybody know location of the brain box for tranny?
Old 06-22-2007, 10:31 AM
Default RE: 99 ml 320 low range when start car
ML 320, sorry been a long day.
Old 06-22-2007, 11:55 AM
1. Start the car
2. Put gear in neutral
3. Press 'Low Range'
4. Press 'Low Range'
5. Turn off the car
6. Start the car and you will not see 'Low Range' light flashing
Old 08-05-2010, 09:48 AM
Default Low range light
I'm having the same problem on my 98. I tried the remedy but no luck. I have never had the need to use the low range. Should I be concerned about bigger transmission problem?
Thread Thread Starter Forum Replies Last Post
No throttle response in my 99 CLK320, engine rpm oscillates by itself in low range zdzich Mercedes CLK Class 2 08-25-2012 11:21 AM
How to turn low range off stuck in the on postion xxdanielxx Mercedes M Class 4 11-18-2007 12:32 PM
chassis range godtammitt Mercedes C Class 0 11-25-2006 08:47 PM
SLK 350 Lights Auto Range Problem!! tonyb15re Mercedes SLK Class 1 11-21-2006 01:08 AM
Long Range on Central Locking not working raz_1 General Tech 1 10-22-2006 05:47 AM
Tags
benz, blink, blinking, car, flashes, flashing, light, low, mercedes, ml, ml320, ml350, range, rnge, turn
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
