2006 ML350 - How to Reset indicator - service B
Guys, I'm sure a lot of us have gone through this. But for some reason I could not find an answer to this on the forum.
How can I reset the service B indicator - >> 2006 ML350
thanks tons in advance,
RE: 2006 ML350 - How to Reset indicator - service B
Ok I see some intrest in this thread so here goes. I think it's in your owners book.
Turn the ignition to the first position with the drivers door closed. You have to be on the first screen (outside temp). Hit the R button on the cluster 3 or 4 times. You will see battery voltage on the cluster. Press the page down button on the steering wheel and you will see the service menu. Before you do your service I recommend Hitting the - button on the steering wheel one time to the items menu. this will give you a list of numbers that coinside with a service sheet. may be in the owners book, if not you can inquire this if you ask you local dealership real nice.
After you do the service recommended page down to the confermation icon with the - button on the st wheel and push the page down button. You will see a screen that says full service of cancel single items. select full service and hit the page down button. this should then say serviced confirmed and your done. If you get another screen I think you may figure it out. I'll take a look tomorrow.
Page down button is the lower left inside button on the st wheel.
