1999 ML320 CLUSTER LIGHTS OUT
Old 11-10-2008, 02:49 PM
FRANID's Avatar
Default 1999 ML320 CLUSTER LIGHTS OUT
THE ODOMETER, CLOCK AND THE OUTSIDE TEMP GUAGE LIGHTS ARE OUT, CAUSES TO FAIL INSPECTION CAUSE CAN'T READ THE MILEAGE ON THEODOMETER. ARE THE LIGHT BULBS CAN BE REPLACE OR HAVE TO REPLACE THE WHOLE CLUSTER PANEL. AND IF I DO WHAT ABOUT THE EXISTING MILEAGE ON THE ODOMETER. ANYONE HAVE THE SAME PROBLEM AND HOW MUCH THE DEALER CHARGED.
Old 11-25-2008, 08:59 AM
Default RE: 1999 ML320 CLUSTER LIGHTS OUT
I had a 1998 ML320 so I assume the cluster light setup is the same. The bulbs are small and prone to damage so if you are replacing1 or 2, I would suggest replacing all of them approx. 5 or 6 as you have to remove the whole cluster to get at them. The plastic panels on either side of the steering column have to be snapped off(pull straight out) to gain access to the retaing nuts that hold the cluster in. Once the nuts are off, carefully reach behind and release the speedo so you can get the cluster out to replace all the bulbs. If you have the dealer do it, labour is probably $100.00 plus $5.00-6.00for each bulb.
mab
11-06-2008 01:01 PM
slick1
07-30-2007 07:05 PM
bergfurher
11-03-2006 12:09 AM
Quick Reply: 1999 ML320 CLUSTER LIGHTS OUT
