06 ML350 temperature setting for heater/A/C and tailgate issues
Old 04-12-2011, 09:14 PM
mercedes2006's Avatar
Default 06 ML350 temperature setting for heater/A/C and tailgate issues
I have been having an issue with the temperature **** getting stuck on a temperature. This only happens on the driver side temp ****. Does anyone know how to fix this?
How about fixing the tailgate not latching when using the auto close button? Also, I have been having issues with the auto close for the tailgate not working at all. Anyone have a fix?
Old 04-22-2011, 01:09 AM
Scorpio's Avatar
Hi did you solve the temp **** problem? I am having the same problem on ML 320
Old 04-25-2011, 08:43 PM
Default Problem not solved
No I have not. Please let me know if you find a solution.
Old 05-01-2011, 09:55 AM
mbtechny's Avatar
to resolve the temp problem there is a software update for the acc. this has to be done at the dealer. as for the tailgate it sounds like u need an adjustment. usually you adjust the striker on the body. removed the tailgate sill plate. there are 2 t30 screws on the right side . then adjust the striker forward by loosening two t40 screws. this should make the tailgate pop open with more force and help it close properly.
Old 10-23-2014, 04:58 AM
DocMerc's Avatar
Default Fix
Climate control fix can be done at West City Auto Electrical for a Fraction of what it costs from a stealer......call Frank on Melbourne Australia (03) 93181777.
We can repair yours or supply a changeover.
builderdude
09-16-2010 11:17 AM
TITUSA687
09-03-2009 08:25 PM
borabora25
03-24-2008 01:07 PM
inssane3gt
07-20-2005 12:35 AM
Quick Reply: 06 ML350 temperature setting for heater/A/C and tailgate issues
