Check Engine light
Check Engine light
I've had my 2007 450GL for almost a year now. The check engine light has come on at least six to eight times, always requiring a visit to the car shop. Is this common? It's not always the same codes. This last time I was told to change the grade of gasoline. It's quite frustrating and expensive. Any suggestions?
usually those engines have issues with the cam adjuster magnets...very very common on alot of benz's
on certain occasions depending on the codes you have the engine could have to be disassembled to fix the balance shaft gear sproket.
yeah. youll be fine. 95% of the time.
Mercedes had problems with with the Balancer shaft sprocket (rounding off )but it was 95% on the 272 motor not the 273 soo im willin to bet this isnt the problem..what codes did they come up with?
Kikoap
07-30-2012 02:50 PM
Kikoap
03-27-2012 10:37 PM
krisgt2@hotmail.com
09-28-2007 01:41 AM
