2007 Benz GL450 Blistein Air Shock Absorber
I need to urgently purchase replacement part - 2007 Benz GL450 - Blistein Shock Absorber (Air filled). Part number from old part 15.1400-0381.3
PS:
Not able to find this part on several auto pars website.
I'll appreciate useful info on site that keeps this part and indicative price if possible.
Thanks.
adenationwide@hotmail.com
PS:
Thanks.
The Mercedes Benz Gl450 shock absorber is a comprising part of a suspension system and is fixed in the middle of an upper control arm and your current car frame. Inside the solidified outer shell is a pressure tube loaded with hydraulic fluid in which a piston rod moves up -down to. The rod is securely mounted on a piston, which makes this damper operate identical to an excellent oil pump. The part works in two cycles, up or extension and down or compression.
Michael G Marinelli
03-29-2015 03:38 PM
